2g 4g63t from a auto into a manual?
JSand96TSi
34
Feb 21, 2010
Clifton, Colorado
I know this might be stupid and im sorry but I need to know what I need to swap a 4g63t from a automatic and mate it to a manual transmission. Obvioulsy a flywheel is that it?? Any help is greatly appreciated
He's not swapping transmissions from an auto to a manual, he's looking to put a engine from an automatic into a manual car.
Oh, I stand corrected. Thank you for pointing that out TunedDSM. :thumb:
Yeah, you should be able to take off the auto flywheel/torque converter and swap your manual flywheel/clutch on and it should be all you need.
Yeah thats about it. UNTIL you get to that PAIN IN THE A$$ dowel pin in the end of the crankshaft that you have to take out in order to mount your flywheel!!!!!!!!!! Advice would be big vice grips, PB blaster, and alot of time and beer. The pin is pressed in and took me a good while to get out.
The dowel pin is inside the bolt facing that you mount the flywheel to. Its not a small one its like 2" or maybe bigger it sits inside the end of the crank. Maybe your crank doesnt have one but try putting your flywheel on and see.
Are you talking like the lip on the end of the crank? My flywheel came right off without any trouble, I will try to throw the flywheel on and see for sure what u are speaking of.
The best way to get that torque converter ring out is to put a socket just smaller than the inside of the ring and hit around the socket walking it out but use some wd40 or pb blaster to help.
