2G 2G, 4G63 (non turbo) The injectors are not injecting
Maxicarlos
8
Nov 30, 2025
Palma de Mallorca, Europe
Hi everyone, I'll briefly tell you my story. I had my Eclipse 13 years ago and sold it. Now I have the opportunity to get it back, and I'm back here after many years away.
Greetings from Spain / Mallorca.
When I bought my Eclipse again, it wouldn't start.
I started investigating and it turns out it's not getting fuel through the injectors.
I've searched the forum and many people have had this problem, but they haven't posted the solution.
Fuel is reaching the fuel rail.
There's spark at the spark plugs. The camshaft position sensor is working and receiving power.
The crankshaft position sensor is new (from AliExpress) and receiving power.
The fuel pump and MPI relays are good.
I've opened the ECU and it looks fine.
I don't know what else to check 😔
I apologize for my English, as it's a Google translation.🙏🙏🙏
La rampa de inyección se probó en otro Eclipse y funciona.
Google Translate:
The injection manifold was tested on another Eclipse and it works.
Google Translate:
Are they stock injectors or performance? If not stock, are they low or high impedance?
Original inyectors
I'm no expert but I would pull the injectors and do something like this to ensure that they are functioning properly. If they are, hook a tester up to the harness to ensure power is making it to them.
The video says how to clean, but the way are engaging the injector manually is what I'm referring to.
    • george bromwell
    • pma1123
    • Sdcryan1
