2g 16g Install Help
You have a stock 2g so you order the 2g line. When you put the turbo on, do NOT boost more than 12psi being on stock injectors. You will be at 100%IDC. Best to keep it at wastegate pressure until you get your fuel mods and tune.
Yeah I wasn't planning on going over 10psi right now, and thanks for the info it helped a lot! I'm going to get that 2g install kit from Extreme PSI.
