16g install help!!
preludeachris
295
3
Sep 29, 2011
Lincoln, Nebraska
Installing a 16g small turbo and im unsure about oil feed lines and return... my install kit came with a elbow peice with one smaller end and one and one bigger and ss line but neither will go on the turbo itself...can i use the older stuff from my t25? Im out of town and away from my computer at the moment can someone help me out?
You can use the stock water lines from your T25. I also used my stock oil return. I had to drill out the holes on it a little though but afterwards it fit fine. The only thing I needed was a ss oil feed line to your oil filter housing.
