255lph fuel pump...
You can just swap the new one in. Do you have a fuel pressure regulator with the 255?
Here's a good install guide:
http://www.vfaq.com/mods/pump-WB-2GAWD.html
This is the guide I used when I installed mine..didn't have any problems at all. The new pump should come with a little bag filter thing, and you just swap everything from the stock pump over, so as far as I know you don't need any install kit.
