Th3ory
- 219
- 29
- Aug 6, 2015
Centralia,
Washington
Its a bit hard find the proper offset's, I have seen +35, +45. Should a 225/40/18 with +40 offset fit a 2gb dsm?
The race ones do ^^
You can do the measurements to see how far they will stick out from the fender etc. Hope this helps some.
Idk that's kind of tall, they could rub on the upper arms and those will tuck hard in your fenders if you are lowered. 235's are a bit too wide for a 7" wheel, I think theoretically you can do it but you will be rolling the sidewalls cornering. 18x7 is just an odd size, I would look for 18x8 or 18x8.5 if you are really dead set on getting 18's.
