22 to 23 splines swap Eclipse GSX
FlashBack-Cro
196
25
Mar 29, 2011
Zagreb, Europe
I have searched but didn't find exactly what im interested in.
So, here's the story.
I have 1991 Eclipse and i want to make swap from 22 to 23 splines.
I want to buy 23 spline Transfer case, and 23 spline output shaft for my gearbox(now is 22 spline output shaft).
Does it possible to swap output shaft on gearbox to 23 spline?
I hope that You can understand me :)
Thank You.
You can swap a 22 spline to a 23 spline. Go into the DSM tech guides, VFAQ and tutorials, Driveline and read the post called - Changing the ouput shaft(Drives T-case). This is the same whether you are changing the number of splines on the shaft or not. I hope this helps.
U should be able to pop the end case off. Take vc off and detent ball for output shaft and slip output shaft out slip 23 spline shaft in. Then reassemble.
This is it.
Thank you guys for fast response ;)
Btw, this is my problem, so i wan't to change to 23 spline.
From center diff:
One more thing, is this normal play for shaft?
http://www.youtube.com/watch?v=E0VfNpqgKmQ
