20g stock 6 bolt
PaRaNORML
86
Apr 23, 2009
jacksonville, Florida
20 gwith stock injectors intake,3"exhaust and running low boost between 7-14psi will running 100 octane gas compensate for smaller injectors? also is the 20g a quick spooling turbo?
the car should be able to handle 14psi with the stock 6 bolt block and 2g head, exhaust,intake,fmic ,greddy bov? i should be able to achieve 300 hp with this set up right? i do plan on upgrading fuel support though but i wanna know if this setup will run efficently
You're worried about the turbo destroying the short block. Turbos don't break short blocks, boost doesn't break short blocks, the tune breaks short blocks.
You will be at or near 100% duty cycle if you make 300hp with that setup. That's a big if. The 6 bolt short block can handle more than 500hp with a good tune and no knock.
so whats a safe boost level to run ? i know this turbo is good for 400hp but can i achieve a nice amount of power without doing any other mods?
The 20g will make 300 easy, and much more if you get more fuel to it. Quick spooling? Depends how quick you want, I would assume it makes full boost slightly slower then a 16g.
Safe boost for what? Stock injectors?
I would keep the boost low under 8psi.
Hate to say it but don't do a noobie error and get your supporting mods first and something to tune with.
THEN, worry about putting the turbo and all other goodies.
Better to be safe than sorry.
Why are you double posting? You already stated in your other thread you wanted to run 30psi on the stock tune etc. Dont move your post and restate what you were told from it hoping to get a better answer. :notgood:
