2 questions about me boosting
4BangerV8Killer
Banned Member
417
Aug 25, 2004
San Martin, California
one is when im off throttle i am at -20 vac but if i put it in neutral then i go down to -15 vac is that bad or what could it be a vaccum leak? and another thing is when i hit my full 14lbs of boost my car sputters nothing before that but as soon as i hit full boost at WOT i sputter other than that i run perfectly what could that be? started doin it right after i was topping out my car one night :rolleyes: (stupidity)
You've removed the weight of the coasting car driving the pistons to try and suck air against the closure of the throttle plate.
Don't coast in neutral. Ever.
its not my plugs most likely not my mas the wierd thing is if im idleing my vac goes from-20 which is normal when im off throttle but it i put in the clutch or put it in neutral i got down to -15 vac
