insanewayne
- 317
- 1
- May 18, 2004
Ladysmith,
Hey guys.
(sorry this is so long, but could a Wiseman or someone please read
Ok here it is. I have a plan to build up a 2.4 setup using the 4GCS. I would have posted this in the tech section, but I didn't wanted to get bitched at, cause really I just want some Knowledgeable opinions....man I hope some wisemen or mods read this forum
Ok, so first things first, Im in Canada, so were talking CAN dollars here. I own a 91 laser turbo. It has 200k on it...and it's in ruff shape, but runs great. Needs a full rebuild soon, probably a new turbo within 50K and some major body work + paint...but I only paid 1750 for it...so not bad. I posted on BCDSM, for a 1g AWD with a blown bottom end that someone wanted to let go for cheap (which is kinda rare, most people fix them). So there's a guy on the island (Vancouver island) who has a 90 tsi AWD with a blown motor...his water pump failed and the engine over heated...so Im guessing seized pistons or mangled bearings...either way it doesn't matter...all I need is the head... and all other engine parts, so this is perfect. Now I'm broke till November 3rd, but he said he might want to do a straight trade my car for his...at first I was like wtf man, my car is in decent running shape, for now, and yours is blown...but then I thought about all the shit my car needs , and it might be nice just to get rid of it. The guy put some money into it...profec, Greddy TT, rims, gauges n shit, but the trade is without any of that stuff...just mentioning that to show that hopefully he had some care for his car. So first off...what does someone think of this trade?
Ok, so I think I can pick up a 4GCS bottom end out of a sonata for around 200-250$...now if I get one with decent km's on it, is it possible that I wouldn't have to get in machining done? Or should I realize were still on earth here
... My plan was to find a car like the one this guy has, then build the engine over the winter and get it drivable, then when more $$$ comes...upgrade and upgrade and upgrade. From what Ive read...all Id need is this car from this guy, the bottom end of a 4GCS (plug the drain holes etc), some Aftermarket pistons, and remark the 63 cam gears, and use the galant DOHC T-belt? Then I could use the stock turbo for the time being, and smic etc, etc, till I get more money to upgrade as I go. So I was wondering, can the stock 4g63 ECU run a 2.4 or what could I do to get by here without having to buy a DSMLink or standalone setup right away
I always thought the 4GCS came with the 1g big rods...but I just read something different...anyone know the facts about this? If not, pauter/ross? or eagle/ross?
pauter/wiseco? ....
any opinions here as I have never used either product.
For a streetable, but very powerful big boosting setup should I go 8.5:1 or 9:1 ?
Bother with the oil squirters or not? Where do I install the knock sensor... I was never able to find a definate answer in any of the related posts.
I'm not too worried about the turbo upgrade yet, because I won't be able to afford that for awhile...as far as the stock one being able to breath ok, not surge, etc, is there anything I could do to maybe allow more airflow, and not shove 300 degree air into my IC.... Port the Exhaust housing, clip the exhaust turbine?...
Ok Ill try not to make this anymore of a novel then it already is...but what would you guys suggest I prioritize for my upgrades. Oh and I will also have an auto shop available to do this in, but it's just a high school/college one, so no machining stuff there, what should the machining cost me if I need lets say some re-boring....oh and at the same time, Ive read a few times about the need for a torque plate?...what exactly is that, just a plate that the block sits on for machining?
My goal is for the car to be able to run 10's a year or so from now, as my driving skill improves to achieve such an ET, and the required funds become available.
Standalone worth it? Or could I reach these goals with the DSMLink?...
I'm sure I have a few more Questions I forgot to mention, but this is waaaaaay to long already, so if anyone is still reading this, thank you very, very much
Thanks again.
Wayne
)Ok here it is. I have a plan to build up a 2.4 setup using the 4GCS. I would have posted this in the tech section, but I didn't wanted to get bitched at, cause really I just want some Knowledgeable opinions....man I hope some wisemen or mods read this forum
.Ok, so first things first, Im in Canada, so were talking CAN dollars here. I own a 91 laser turbo. It has 200k on it...and it's in ruff shape, but runs great. Needs a full rebuild soon, probably a new turbo within 50K and some major body work + paint...but I only paid 1750 for it...so not bad. I posted on BCDSM, for a 1g AWD with a blown bottom end that someone wanted to let go for cheap (which is kinda rare, most people fix them). So there's a guy on the island (Vancouver island) who has a 90 tsi AWD with a blown motor...his water pump failed and the engine over heated...so Im guessing seized pistons or mangled bearings...either way it doesn't matter...all I need is the head... and all other engine parts, so this is perfect. Now I'm broke till November 3rd, but he said he might want to do a straight trade my car for his...at first I was like wtf man, my car is in decent running shape, for now, and yours is blown...but then I thought about all the shit my car needs , and it might be nice just to get rid of it. The guy put some money into it...profec, Greddy TT, rims, gauges n shit, but the trade is without any of that stuff...just mentioning that to show that hopefully he had some care for his car. So first off...what does someone think of this trade?
... My plan was to find a car like the one this guy has, then build the engine over the winter and get it drivable, then when more $$$ comes...upgrade and upgrade and upgrade. From what Ive read...all Id need is this car from this guy, the bottom end of a 4GCS (plug the drain holes etc), some Aftermarket pistons, and remark the 63 cam gears, and use the galant DOHC T-belt? Then I could use the stock turbo for the time being, and smic etc, etc, till I get more money to upgrade as I go. So I was wondering, can the stock 4g63 ECU run a 2.4 or what could I do to get by here without having to buy a DSMLink or standalone setup right awayI always thought the 4GCS came with the 1g big rods...but I just read something different...anyone know the facts about this? If not, pauter/ross? or eagle/ross?
pauter/wiseco? ....
any opinions here as I have never used either product.For a streetable, but very powerful big boosting setup should I go 8.5:1 or 9:1 ?
Thanks again.
Wayne
