2.4 stroker
Is this for your 91 GSX? If so you'll need a 4g64 for the 2.4 setup.
First off, 2.4 isn't a stroker motor, its a whole different block that's 2.4l. Taking the 100mm crank out if the 2.4 and using it in the 4g63 block is a 2.3 stroker. The factory crank is plenty strong. Plenty of cars making well over 500whp, myself included. If you want to make more torque the stroker is a great way.
