2.4 Liter G4CS build thread
Atuca
Supporting Member
1,145
303
Jan 6, 2007
Central Valley, California
Well Santa came early wearing all brown!
I got my packages this last weekend and spent several hours sorting through all the parts, matching part numbers and ensuring everything turned out great. Props go out to Slowboy Racing, Kiggly, and VR Speed Factory for the great prices, and wonderful service.
These are the parts I have ordered thus far, and as I was checking off my "master" list I noticed I forgot a few items, i.e. timing tensioner and pulleys, external oil cooler, things that smart people shouldn't forget heh. But I'll make another order through these folks and will be alll gooood :)
1. Freeze Plugs Top Line
2. Rod Bearings ACL Trimetal Race 4B1146H-STD
3. Main Bearings ACL Trimetal Race 5M1144H-STD
4. Main Girdle Kiggly
5. Main Studs ARP 207-5401
6. Balance Shaft Removal Kit MD040597,MD103722,MD092785,MD098626,MD128107
8. Timing Belt 2.4l g4cs / 4g64 OEM belt md331076
11. Tensioner Arm OEM Timing Belt Tensioner Arm MD-130032
12. Harmonic Balancer Fluidampr FDR-630701
14. Crank Pully Bolt ARP 207-2501
15. Water Pump and Gasket MD972052
19. Oil Filter Bracket Gasket MD149370
20. Oil Pump Front Case MD175762
21. Oil Pump Front Case Gasket MD149393
23. Castle Nut Plug MD125376
24. Castle Nut Plug O-Ring MD041021
25. Crankshaft Rear Oil Seak Gasket MD183243
26. Crankshaft Rear Main Seal MD343564
33. Stud to Transfer Case MD065945
35. Oil Tube O-Ring MD075834
36. Oil Strainer Gasket MD183240
38. Cylinder Block Dowel Pin MF472403 x2
39. Cylinder Block to Head Bushing MS471111 x2
40. Cam Gears 90-99 Eclipse 2.0L turbo (blue) - Fidanza 961999
41. Cam Gear Bolt MF140285 x2
42. Cam Gear Seals MD372536 x2
43. Springs and Retainers Evo VIII
44. Lifters Topline TPL-LIFMI6-16
45. MLS Headgasket Cometic C4235-051 87mm
46. Head Studs ARP 207-4201
47. CAS O-Ring MD619648
48. Intake Manifold Gasket MD188995
50. Thermostat Housing Gasket MD145038
51. Thermostat Kit MD997607
57. Flywheel XACT Streetlite 600150
58. Throttle Body to Manifold Gasket MD146399
59. Throttle Body to Elbow Gasket MD340327
Next bit of business, is with all these parts, I believe I am ready for the machine shop. :hellyeah:
As for the engine harness, it is still coming along. I am at the point now where I am routing the locations of the wires, relocating, and planning out how and where I am going to put new plugs like Eric did. Man that guy and his bro have been so much help, another props to him on finally finishing it last weekend!! :thumb:
Thats all for updates, I have questions posted in my build THREAD, feel free to swing over there if you think you can answer :)
This is perfect, I'm starting the same build in about 3 months....
And I just found Another g4cs, I think I will snag as a spare, since these are tough to find.
Thanks for that parts list! I'm sure I will be referring to your blogs down the road.
Just note, while this list is inclusive of all 6 bolt swap parts for this motor in a 2g, I can't be 100% it will work with anything else. It took me forever to get that list together, and looking back, its only some of the parts LOL.
It was a good start though, I won't know that list is perfect until I put everything together and see if it runs :p
Good luck on that headgasket. They are a b**** to get to seal.
As long as the head and block are both resurfaced there shouldn't be an issue. Unless there is something else I am forgetting?
Some have better luck than others with the headgasket. On low boost they are fine, Turn the wick up and they always seem to blow between the cylinders.
For that reason, I like the Felpros and Mitsu ralliart headgaskets.
