vaboys2ndgen
- 1,126
- 0
- Jan 5, 2005
Fredericksburg,
Virginia
JUST WANTED TO GET IDEAS OF WHAT IM MISSING. 1ST BUILD.. SO BARE WITH ME. IM AM ABOUT READY TO ORDER THE INTERNALS FOR THE BUILD. STARTING WITH A BARE BLOCK AND BARE HEAD ALSO.
2.3l
BOTTOM END
Wiseco piston .20 over 8.8:1
eagle h beam rods OR crower rods
balance shaft eliminator kit
new 4g63 oil pan
clevite main and rod bearing sets
arp- rod, crank bolt(s) main, head studs
new topline front cover w/ oil pump
new oil pickup tube
new oil filter housing
HEAD
new mitsu valve stem seals
manley 1mm over valves
manley springs and titanium retainers
brian crower 280/280 camshafts
revised lifters
kevlar timing belt
new mitsu water pump
new timing belt cover
piston oil squirters
BASICALLY TO HAVE THE MOTOR ASSEMBLED AND SITTING ON A STAND READY TO DROP INTO THE CAR IS WHAT I AM LOOKING FOR INSIGHT ON. ALSO NOT WORRIED ABOUT BRAND NAMES JUST SPECIFIC PARTS IS WHAT IM LOOKING FOR.
THANKS AGAIN
-JPICK (IN IRAQ)
2.3l
BOTTOM END
new 4g63 oil pan
new oil pickup tube
HEAD
revised lifters
kevlar timing belt
THANKS AGAIN
-JPICK (IN IRAQ)
what would you recommend (ie. replace front and rears?) anything else to into as to replace making the 500-600whp power.
