2.3 Stroker w/ 660 fuel map
Stroked_DSM
Aug 16, 2009
Dudeville, Tennessee
First off, I'd like to say that I'm new to tuning.I have an SAFC2 and a wideband to tune the freshly built 2.3 stroker 7 bolt. I have a Evo 3 16g and 660 injectors. I was wondering if anyone who has a similar build to mine could share what they have set on their fuel map or give me advice on how to tune this thing. Thanks
If you got a wbo2 and datalogger than you are set. All you have to do is setup the safc for the 660 injectors. Then get fuel trims as close to zero as possible with the lo settings. Once fuel trims are inline just start to lean out WOT untill you get around 10.8-11.1 afr if running pump gas. I like to run 10.9's on pump. Seems to allow the most boost and timing.
