2.3 7Bolt Head Gasket
TalonSpeed
526
21
Dec 22, 2002
Little Rock, Arkansas
I have a 2.3 7 bolt with 100mm crank and .040 over pistons (86mm). Is it okay to use a 87mm felpro permatorque head gasket?
My cometic MLS 86mm gasket blew. Engine is pushing coolant and i see signs of oil in the coolant.
The extreme psi Felpro\ARP L19 stud package is $399
EXTREME PSI : Your #1 Source for In Stock Performance Parts
no dont use copper spray on a composite head gasket
Before you decide to take a members word on this ,look around the forums for previous mention on this, it has been said that its not recommended to use copper spray on an MLS HG but its not necessarily bad either. More times than none I have seen on this site to use Copper spray on a composite HG. To each his own. :hmm:
the kit the op links, is of an MLS HG, Not a Composite.
But remember to have your Head an Block mirror finish prior to install.
