1st gear poping out.
teamitr
100
Jun 14, 2005
Riverside, California
Quote:
Originally Posted by Red Sleeper
I had this problem with my old laser. Its either the snycro's/shift fork bent a little bit. or the linkage is misadjusted. Also. where the linkage bolts to the trans. There are special washers that you have to have to make sure everything is centered. that ended up being my problem. Hope this helped a bit
I'm having the same problem as far as 1st gear popping out when realeasing the clutch and I checked the linkage and where it bolts on to the trans it was missing one the the two bolts that holds it in place and the other bolt was loose, so i thighten down the bolt and i found another bolt to replace the one that was missing. now the shifter felt 200% better but it would still pop first gear out, and if i down shift to first it will go in and stay there and i can floor it and let go and it will still stay in gear. now my question is do i need that special washer that Red Sleeper is talking about?
by the way i used Lucas Heavy Duty 80/90 Gear Oil.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
