1st gear grinds
motoracer1125
Apr 21, 2009
mayfield, Pennsylvania
hi my friend has a 95 eclipse gsx and it grinds in first gear and was wondering it he has to take the transmission out of the car to fix that or if he can just pull the side cover off and get to the syncro's and shift forks? maybe someone else has had this problem and found and easy was to fix
It could be a clutch engagement issue.. I would first check into that but if that is right then the trans must be pulled...
Could be clutch adjustment or cable adjustment too... I would try all the small things before tearing that sucker out LOL... Good luck!
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
