1st 12-13psi, 2nd 15psi, 3rd 17-18psi
Status
Not open for further replies.
COHIBAGSX
38
Feb 27, 2004
MANAGUA, Central America
hello dsmers! :dsm: i need help. my car is running nice, you can feel the power, but one problem. boost isnt constant. in 1st gear it boosts 12-13psi. affecting my launch. i take off at 4500rpm (awd) it jumps then dies and takes off as the turbo spools up. 2nd gear it hit 15psi 3rd it hit 17-18psi. dont know what is causing this difference in boost per gear. checked the turbo out and it is fine. my profec-b is all good. i think it maybe settings on my apexi super afc II. can the afc setting affect boost? thanks! :thumb:
:dsm: ive tried launching at every rpm. started out at 3000rpm, 3500rpm, 4000, 4500rpm, 5000rpm, 5500rpm, burning clutch & poping clutch. the higher the rpm the bigger the jump. it still falls and then picks up. the fastes time i pulled on the g-tech pro was a 14.7 :cry:
You already have one thread working on this issue.
Do not post it again.
Status
