2G 1gina2g Parts List, What did i forget?
zerofreez
247
Aug 6, 2002
Madison, Wisconsin
I was wondering if anyone knew of anything else i might need, i just ordered all the small parts yesterday. Hopefully i have everything.
I still have every part from my 7 bolt motor, but i have no parts from a 1g engine unless specified.
I started with a bare 6 bolt block
6 bolt short block
1g head
1g intake manifold
1g tb
14b turbo
air/air oil cooler
Engine Gasket Set
Head Gasket Cometic HP
Crank Pulley
ARP Head Studs
2g Knock Sensor
CAS Sensor
2g Oxygen Sensor
2g Oil Pressure Guage Sensor
2g Oil Pressure Dummy Light Sensor
SS Oil Feed Line.
Rear main seal and housing
Accessory Belts
Timing Belt Components
Timing Belt
Timing Belt Tensioner
Idler Pully
Tensioner Pully
Camshaft/Crankshaft Drive Pully
Tensioner Arm
Timing Belt Cover
Oil System
Oil Pan
Oil Drain Tube
Front Case
90 style Oil Filter Housing
Oil Pump Drive Sprocket (timing)
Cooling System
Water Pump
Water Pipe
Thermostat Housing
Thermostat Neck
1G Water Feed Line
1G Water Drain Line
Lower Radiator Hose
looks like ya knocked it out pretty good to me, im doing the EXACT same swap right now.
Im not sure if you need to swap the
2g Oxygen Sensor
but obviously it wont hurt, i might do so since mine is just laying here anyway..
exactly what is "head gasket cosmetic HP"?
2g Oxygen Sensor
I am using a 1g oil pressure sensor hooked to the 2g stock guage, it works perfectly fine:)
As far as teh dummy light sensor, remove it, replace it with an autometer guage sensor.
I got the oil sensors because mine were damaged with my 2g engine sitting on the floor of my garage.
I have a 6 bolt act flywheel
and as for the pointimeter or whatnot for the random misfire, dsmlink will be here shortly.
Two things i added to the list today were...
2g starter plate/dust sheild between engine and trans (mine is bent up)
Clutch fork and pivot ball (mine as well for 60 bucks, mine had 180k on it)
ohh that reminds me, i might aswell stick another washer under my pivot ball.
Its the best head gasket you can get. ForcedPeformance and Magnus sell them.
its cometic though like CO METIC
its not somthing you get from the avon lady :p
    • george bromwell
    • pma1123
    • Sdcryan1
