1gblockon2gheadina2g what kinda clutch should i get?
97spydagst
268
May 14, 2004
Burley, Idaho
gettin a 6bolt in my 2g what clutch shoudl i get it for a 7 or 6 bolt?? also i need a timing belt what should i get if for a 97 or 91? im confused let me know thanks :dsm:
ACT clutch kits are the exact same for all years of turbo DSM. The only thing that is different is if you buy a flywheel from them also. As far as the timing belt they should be the same for all years but I do believe the tensioner is different for the 1G. Someone else chime in here and correct me if need be.
On a side note,
Are you going to replace the 2g head with a 1g anytime soon?
It will benefit you if you do. The 1G head flows better than the 2G in the stock form.
Just asking.
midnght said:
On a side note,
Just asking.
nope dont think so what if im using a stock clutch which should i get 1 or 2g???????? i blew my bottom end so im jsut gonna get a 1g block and put it on for 200$ it sounds good to me thanks alot
You need the timing belt for a 1G (if theres even a difference) and a 91 clutch, but their the same. If you get a new flywheel then you need a 6-bolt FW. Thats it!
ok thanks is there any tips u can give me to get me ready??? any info will help
