1ga Eagle Talon Vacuum Leak
misterjose
169
Jan 1, 2010
Los Angeles, California
i have a vacuum leak that i can't seem to find. i got it down to a specific area, but when i did that spray bottle with soap test i did not find any bubbles. anyone want to help me out find this sucker. im thinking its my uicp where it bends to the throttle body but i dont feel any leaks or see any bubbles. I live in LA 90020
any help would be greatly appreciated. :pray:
Does you BOV leak back into your intake pipe? You could take off your recirculation tube while you BLT and put you hand over the opening to feel for leaks.
Usually a 1g BOV will leak a little past the valve stem seal inside the BOV. You can fix that with a dodge mod, combined with a Gus Mahon BOV solenoid mod. http://www.gusmahon.org/html/Talon BOV.htm
http://forums.evolutionm.net/evo-ho...gus-mod-dejon-tools-leak-stop-kit-mr-bov.html
Ps. If you need more help, send the plane tickets to: Dayo's Garage 15 Fillmore Ave. Tonawanda NY 14150. Two please, (I travel with an assistant) First Class only.
Are you trying to find the leak with the car running? If you are try getting a bolt on tire valve at the hardware store then find an appropriate size cup you can drill that will fit into your intake pipe. after you tightened the valve in place and clamped the assembly to the intake, watch the mechanical boost gauge and put around 15 psi into the intake. This will bled off slowly but at this pressure and the engine off you will be able to pin point your leak. I've used this method numerous times to find those phantom leaks.
will do a boost leak. asap
but these are my mods 16g turbo, headers, no cats, evc 3, my throttle body elbow says hks. i will do a video. idk how i cant find the leak because i can hear that sucker!!!! even with an exhaust and headers. my car idles really low on starts at 500 rpm but once warmed it idles about 750.
@COLT4g63 !!! HAHAHAHA! once i win the lottery i will do so! ill even have you picked up with a limo, but be ready to get your hands dirrttyyyyy!! LOLo
I've seen people do this too. Rent a fog machine from someone. Open it up. Inside there will ne a coiled copper pipe where the fog comes out. Hook up one of the lines to the fog machine then just look for the fog. But only use the machine in 30 sec intervals, so you don't ruin the vaccum line. Because all the fog is made of is water and glycol. Yeah. Antifreeze basically. Just once you find and fix the leak take the car for a short drive to clear out any unwanted left behind water or residue. And such a small amount should hurt anything.
Make a boost leak tester, sounds like it may be coming from the EGR area. You can use some baking flour and look for the ploom, do it in a garage where theres no air interference if you want to try something different.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
