1G 1GA AWD Brake Differences
algomni
42
May 11, 2014
Frankfort, Indiana
So searching around on Rock Auto, I found these rotors : http://www.rockauto.com/en/moreinfo.php?pk=4423116&cc=1103050&jsn=336&jsn=336
It says it will not fit a 1990 Eagle Talon AWD, but it will fit a '91.
My main question is why? What are the big differences? Would they bolt up if I happen to buy them?
Or will I have to buy all the rotors separately since they don't offer a nice kit like this one for the Talon.
Thanks in advance guys!
There are part number differences between the 90 and 91 for the front disks and according to the FSM changes in the calipers and rotors between car built before 4-1989 and after but I suspect that was also around the start date of the AWD cars.
May I suggest you consider getting the larger dual piston calipers and matching rotors. I never found the stock front brakes to be up to snuff even with good pads and rotors.
The 90 and 91 rear brakes are also different.
What years had those?
92-94 GSX were equipped with them. Donor parts can come from the 93-94 AWD DSM, 91+ NA 3000GT's and Stealths, 92-96 Diamantes.
If you have 17" or larger wheels the Outlander brake swap is also an option
http://www.vfaq.com/mods/BigBrakesInfo.html
http://www.vfaq.com/mods/BigBrakesInstall.html
http://www.dsmtuners.com/threads/05-06-outlander-bigger-brake-upgrade.428973/
Do you think this would work well for the fronts if I got the brackets? http://www.rockauto.com/en/moreinfo.php?pk=7283896&cc=1103151&jsn=684&jsn=684
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
