1G Will Not Start help
dsmdemon92
Mar 29, 2008
hunker, Pennsylvania
HI I have a problem here this is the first time i could not get one of these to start i have owned 6 in my life time and this has never happened please help the car is a 92 with a 6 bolt in it i have fuel i have spark my coolant temp sensor is good it just keeps flooding out and will not start any ideas thank you very much
Funny I'm have the same problem with the same year minus mine is Fwd. I'm thinking mine is a fuel pump. I am getting fuel in my oil though...Does your's turn over atleast? Just won't start?
Mine does that when it's below 35 degrees outside. When it floods out, I open the rear hatch and unplug the fuel pump. Then i crank it until it starts and runs out of fuel. Then I plug the pump back in and start it with the throttle wide open. Sometimes it takes a couple of tries. It starts fine all day after that. I bought a logger cable to try and diagnose the problem, but the cable is defective, so I have to wait for a replacement. I'll update when I find out the problem with mine. It only started doing this after I put a new engine in it.
