1g throttle bodies
Night479
Dec 8, 2008
Oxford, Michigan
simple question can i use a 90 TB on my 91 tsi? i know theres differences like isc but they are interchangable to fit but havent put them to the test.
The 90 TB is slightly wider, but should still bolt up. You will have to re-wire the throttle position sensor. The vacuum lines are in different locations on the TB so if you use those you would have to figure out the new routing.
I would just pick up a 91-94 TB, press in new shaft seals and call it a day.
