1g Tensior arm in a 2g..help!
Marsh
Sep 4, 2003
Hello
I am swaping a 6 bolt into a 2g. I cut the motor mounts and such, but the tensior and the tensior arm don't line up. I have a 2g tensior arm and a 1g tensior. What is the correct thing to do? Do i need to get a 1g tensior arm? Do i even use my tensior? Any help would be appreciated. thanks
Both the tensioner and the arm should be from the same gen. Using 1g components will save you a lot of hassle. The only down side is you will no longer be able to make use of the timing belt tensioner tool as the hole in the 2g mount no longer lines up with the tensioner arm.
Join the yahoo group 1gina2g and you will find wealth of info there.
-treebonker
Yea, i need to get a 1g tensior arm, but hard to find. Whats website again that has all the info about using 1g tensior stuff? I have pretty much all 1g parts except tensior arm, and balance shafts removed. Thanks
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
