1G TB Idle Stop Switch thread pitch
Cox Abele
485
56
Jul 4, 2010
Roanoke, Virginia
I have installed an Evo3 intake and 1g throttle body on my 7-bolt 2g. I'm running the 2G TPS and don't need to use the 1g idle stop switch since it's built into the TPS, however I do need install a throttle stop screw. I do not have an idle stop switch to take with me into the hardware store. In both 2g throttle bodies I own, there is a machine screw that does the job of stopping the throttle plate from closing "too far," allowing the throttle blade to bind. In a 1g, the idle switch has a dual purpose as a switch and a throttle stop. I need to size and pitch of the 1G throttle body so I can get a bolt in there to act as a throttle stop.
What is the thread pitch and size of the 1g throttle bodies idle stop switch?
