1g Sunroof "Visor" // removing sunroof glass
Pull the latching lever down & forward as though you were tilting it to open; then squeeze the two arms behind the lever together and pull them down & out of the catch/mount. At this point you'll be able to tilt the sunroof up & remove it by lifting it to the rear & out of the slots in the front.
awesome man thanks for the reply
I took these a while back and intended to resize and post them since many people don't have the owners manual.
You actually have to squeeze the silver two armed latch together (it's spring loaded) to get it to start to come out here.
But since I need one hand for the camera you don't get to see that.
Latch is now free.
This is how you squeeze this part when taking it out or putting it back in the mount
List up the glass and it will come out.
A better view of the fitting up front where both the glass roof and the air deflector fit.
You can just see the catch on the passenger side the holds the deflector down.
The last picture shows the releases for both sides to remove it.
Can someone post a picture of the cloth panel that blocks sun from coming in? I have the 1/4 sunroof piece but I would like the other one too. THanks
