Vegas Smith
- 5,193
- 3,156
- Dec 2, 2002
Houston,
Texas
Is your fuel pressure really set to 37psi................................................................
Why do you think its at 37?
Yeah not sure what's going on here.
Strange!! Guess we can't go by what we see in logs as far as fuel injector calculations go.
I just downloaded the Log and see the same thing as you but as pointed out it's the same correction as 550cc @ 43.5 psi
DSMLink only uses the correction % but the calculator knows that a 1G factory base fuel pressure is 37 psi and the stock injectors are 450cc so it's calculating the injector size using those constants.
Once I bumped the pressure to 43.5 and started dialing in MAF, it's more in the 80s now. I'm guessing I can bump the fuel pressure to 50bfp (max???)
Do you know how accurate HP and torque numbers are in link? And that's estimated at the crank correct?
Would you say next thing I need to dial in injector slider?
Yes. That's what the calculator does, figure the difference between the stock fueling and your setup. So your 550's @ 43.5 psi are 24.6% larger than the factory 450's @ 37 psi in flow rate. If this was a 2G ECU the global would be different for the same injectors because of the higher factory base fuel pressure.Correction percentage??? Is that what global is?
