1g rear into a 2g?
NO, the rear diff housing from the 2G are different than the 1G, mounting bolts are not in the same location. I even think that the axles will not fit too cause the 2G got wider distance between each wheels.
Sry to dig this back up.
OP, you CAN swap the DIFFS but not the housings, as long as both are 4-bolt, and both are from M/T vehicles. Basically you would have to install your gear ring from your 2g onto the 1g diff, and shim them properly, but yes you can swap a 1g rear M/T 4-bolt diff into a 2g M/T rear housing.
The part numbers are the SAME.
