eclipse_16g
278
26
Oct 8, 2008
Connecticut
Wanted to share my experience troubleshooting the clutch hydraulics and pedal assembly on my 1G DSM. Hopefully this helps someone avoid replacing parts unnecessarily or spending hours bleeding a clutch.
My GSX sat for approximately 25 years before I started bringing it back to life. One of the to-do’s is getting the clutch bleed and ensure it’s working properly.
1. The Original Problems
When I first started working on the clutch, I had several symptoms:
  • Clutch pedal would drop to the floor and sometimes stay there.
  • Little to no hydraulic pressure, even after repeatedly pumping the pedal.
  • Clutch fluid reservoir was full, with no obvious fluid movement.
  • Slave cylinder initially showed no pushrod movement.
  • Pedal would only return about halfway and needed to be pulled back up manually.
  • Approximately 4–6 inches of excessive pedal travel before the linkage began engaging the master cylinder.
  • The transmission could be shifted through the gears with the engine off.
At first, everything pointed toward a failed clutch master cylinder, slave cylinder, or air trapped in the hydraulic system.
2. Replacing the Clutch Master and Slave Cylinders
I replaced both the clutch master cylinder and slave cylinder. Inspected the rubber flex hose, hard lines, fittings, and connections for restrictions, deterioration, and leaks.
3. The Bleeding Issues
After replacing both cylinders, I repeatedly attempted to bleed the clutch.
I went through more than 25 bleeding cycles and eventually stopped seeing air bubbles, but the pedal still wasn’t functioning correctly.
I was getting approximately 1/2 inch of slave cylinder pushrod movement, yet the clutch pedal continued to have excessive free play and wouldn’t return completely.
4. Finding the Actual Mechanical Problem
While inspecting the clutch pedal underneath the dash, I noticed that the clutch pedal moved several inches before the shaft and linkage started turning enough to operate the master cylinder pushrod.
Through research I found out that that the 1G clutch pedal shaft and actuating lever have a mechanical connection that can wear over time.The lever is retained on a shaft with machined flats. When that connection wears, the pedal and lever can move independently.
This results in lost pedal travel before the master cylinder even begins its stroke.
How- to write-up:
Diagnosis:
  1. Get underneath the dashboard with a flashlight.
  2. Locate the clutch pedal shaft and the lever connected to the master cylinder pushrod.
  3. Slowly depress the clutch pedal by hand.
  4. Watch the pedal shaft and actuating lever.
  5. Look for independent movement or a delay before the lever starts operating the pushrod.
  6. Pull the pedal upward and check for excessive movement above its normal resting position.
If the pedal moves significantly before the lever follows, the pedal assembly needs attention.
5. Removing the Complete Clutch/Brake Pedal Assembly
Note: it can be done without removing the entire dashboard.
Tools:
  • 12mm sockets and wrenches
  • Ratchet extensions and swivel joints
  • Pliers
  • Screwdrivers
  • Flashlight or work light
  • Penetrating oil
  • Protective eyewear
Step-by-step removal (By the book):
  1. Disconnect the negative battery cable.
  2. Remove the driver’s seat for additional working room.
  3. Remove the lower dashboard/knee panel beneath the steering wheel, including any attached hood release hardware.
  4. Remove the steering column plastic covers and lower air ducting as necessary.
  5. Disconnect electrical connectors and wiring retainers that interfere with the steering column.
  6. Support the steering column and remove or loosen its mounting brackets. Carefully lower it for access. Avoid disconnecting the steering shaft unless necessary.
  7. Disconnect the brake pedal pushrod from the brake booster linkage by removing its retaining clip and clevis pin.
  8. Disconnect the clutch master cylinder pushrod from the clutch actuating lever.
  9. Unplug the brake light switch and clutch pedal/interlock switches.
  10. Unbolt or reposition the interior fuse/relay bracket where necessary.
  11. Remove the accessible pedal support mounting bolts underneath the dashboard.
  12. Remove the steering column support brace if it obstructs the pedal assembly.
  13. In the engine compartment, remove the clutch master cylinder mounting nuts and move the cylinder clear of the firewall as required.
  14. Remove the necessary brake booster mounting nuts and carefully move or remove the booster as needed to release the pedal bracket. If brake hydraulic lines must be disconnected, plan on bleeding the brake system afterward.
  15. Return underneath the dashboard and check for any remaining mounting bolts, wiring, or brackets.
  16. Support the pedal assembly while removing the final fasteners.
  17. Carefully rotate and maneuver the complete clutch/brake pedal assembly out from underneath the dashboard.
It takes patience and some awkward positioning. The steering column, brake booster, and surrounding brackets are the biggest obstacles. (I have to trim a metal bracket underneath in front of the brake cylinder to allow freedom of movement).
6. Disassembling and Rebuilding the Pedal Assembly
Once the assembly is out, the worn parts are much easier to inspect.
  1. Photograph the complete assembly.
  2. Mark the relative positions of the clutch pedal shaft and actuating lever.
  3. Remove the shaft retaining hardware.
  4. Replace the worn bushings and any damaged shaft or lever components.
  5. Lubricate the appropriate pivot surfaces with compatible grease and reassemble.
Do not assume that new bushings alone will fix a severely worn lever-to-shaft connection.
7. Sourcing the Brass/Bronze Bushings
Picked up a new brass bushing from ExttemePSI they sell the JNZTuning bushing.
8. Welding the Clutch Pedal Shaft/Lever Connection
This is the repair many people recommended after rebuilding the worn pedal shaft connection, the critical detail is positioning the pedal and lever correctly before welding. If you weld the connection with the pedal in the wrong position, you can lose master cylinder travel or run out of pushrod adjustment.
The general approach:
  1. Install the new bushings and assemble the shaft and lever.
  2. Tighten the retaining hardware correctly.
  3. Pull the clutch pedal fully upward into its intended resting position.
  4. Rotate the actuating lever to eliminate lost motion in the direction that operates the master cylinder.
  5. Mark the correct alignment.
  6. Have a qualified welder secure the shaft-to-lever connection while maintaining the correct alignment.
  7. Inspect the weld and check the assembly for binding, deformation, or restricted movement.
Do not weld the pedal to the support bracket or weld any pivot that is supposed to rotate. The objective is to eliminate unwanted movement between the shaft and actuating lever, not to immobilize the pedal assembly.
9. One More Issue: The Clutch Safety Switch
During this project, I also ran into an unrelated starting issue caused by a missing rubber clutch pedal switch stopper/grommet. That small rubber piece can prevent the clutch safety switch from operating correctly and cause a no-crank condition.
Before assuming its the starter, relay, or ignition switch, inspect the clutch interlock switch and the rubber stopper where the switch contacts the pedal.
Hopefully this helps another’s save some time, money, and frustration.
