1g not running right after gm maf and translator
TSi Kid
12
May 31, 2009
Avondale, Arizona
i've got everything set to 0 except base which is set to 2, for my 450s
car sounds like is running on 3 injectors and will die after it runs for a couple seconds
i'm going to try another maf and see if that helps but after that i'm out of ideas
any suggestions?
any suggestions?
If you don't get it figured out today, i can come by tomorrow and take a peek. I would swap in richards translator first, to rule out a bad unit.
Make sure the arrow on the maf is pointed towards the throttle body, and a boost leak test isn't a bad idea either. just a thought
figured it out
it wasn't the translator or the maf but i had a wet coil pack
swapped it out and its running fine
next step, 1200s and ethenol
