1g N/T help
clipto
2,316
5
Oct 8, 2011
Portland, Oregon
I have 1g non turbo and it was running fine, but after a basic tune up of sparkplugs and wires and coil pack it will just sit there and crack, but I wont get any spark. I checked the mpi fuse and the only thing I can is the power transistor. Anyone have any ideas what it could be?
You changed the coil pack? Are you sure it was a good coil that you used? Have you tried your old one again? If it was working fine and you changed something and it stopped working, I would first suspect the thing that you changed, not something else.
If it did not run at all after look and see if u knocked a wire off. Or like they say bad coil pack, wrong order of plug wires
Double checked the sparkplug order, checked the old coil pack but also the 2nd coild pack I got was a brand new coil pack. It stopped running after the tune up, it would only crank, but no spark.
My bad it did start after I did the tune up. Edit from last post.
Both coil packs test good btw.
