1g N/T mods-Help
IC19
Jun 13, 2005
Mount Joy, Pennsylvania
Hi, ot any onme that can help...
1990 Mit Galant 2.0 DOHC 4g63 n/t fwd
Getting an intake, and an exhaust with highglow cat, 2.5 inch pipe and high flow muff.
I see All theses "Free mods", but they are under the Turbo....Can i perform any free mods...
I see all kind of parts for Eclipses.....90-94 n/t, but non for a galant.....
They have the same engine.....can i still use these parts?....
Thanks to any one that can help a bro out..
PEACE
IC19
some of the free mods will not work, for example the removal of the bcs wont work for you because you dont have a bcs in a n/t engine. as for the parts they will fit the engine, the question is will they fit the frame of the car? for pipes and things i would try to get things like a custom cai measured and bent for you instead of buying parts and hoping there are not fitament issues
Sell the car and buy a turbo model with the money you waste on trying to make your n/t faster you can use it for a faster car stock that you will end up with a n/t modified :)
You can install 1g turbo cams, Larger plug wires ect. Only problem is that you cant use a logger to see your progress cause they wont comunicate with the non turbo ecu. There are allot of things that you can do to make it quick tho. :dsm: :talon: :laser: :cool:
a logger will work with his ecu,mine works fine(mmcd).you can hack the mas,get bigger exhaust,pulleys,plugs/wires,turbo cam,just like everyone said.just everything short of turbo mods.
