1g motor in a 2g
99 gst spyder
522
Jul 12, 2007
st. paul, Minnesota
Stupid but I found a clean 99 eclipse shell without the motor and is in good condition along with everything else. I have a good running 91 talon built bottom and I was wondering if it'll be hard to put that motor into a 2g shell since I like the body style better. I have the motor, ecu, main wiring harness and everything I need to do the swap. What kinda problem will I encounter doing the swap.
awd to an awd.
Thanks
The swap is easy man. i just did it my self. no if you wanna keep link you will neex to get it for your 2g ecu. this was the first time i did this swap and i nailed it in one shot. now im just working out issues that wete there becofe i swaped motor.
