1G 1g manual to auto swap?
turbo4awd
206
Dec 19, 2008
Carlisle, Pennsylvania
I was looking into doing a manual to auto swap on my 1g AWD I did some searching but all I found was auto to manual swap info.
I know I need a auto trans, transfer case, tq converter, shifter linkage, TCU, and Kiggly flex plate. What else would i need to complete this conversion?
Would I have to swap to a auto rear diff as well because of the the different ratios?
Any and all help would be greatly appreciated.
Subscribed for info.
If i ever get into seriously dragging this thing, i'm going stalled auto.
I'll try to dig up all the info i found. I ended up selling my 5spd and buying an auto. Its pretty involved. Trans mounts are different, rear diff is a different gear ratio, and there is some spacing issues with the flex plate and stall. The shifter linkage and center counsel is a little different. You can run the roadsurge box and eliminate the tcu for ease in swapping over.
If you had a auto donor car i guess it would be fine, but it may be a chore tracking down everything you need. Then the swap itself is going to take some hours.
i do have a auto donor really would hate to take out my 4 bolt rear. Hopefully there is a way around this
