1g laser tansmission swapped into 1g talon
i just swapped a 90 into a 91 so im sure it would word the other way, just have to use the brackets holding the cables from your original trans
Yes, it will work just fine. The basic mechanics of all 1gs are the same, just some wiring/routing differences.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
