GVR-4 Motor Swapped into 93 1G
tsiunderpsi
Aug 20, 2005
Sandpoint, Idaho
Hey all,
Just discovered my 1g 7 bolt motor has walked :cry:
So, looking at the possibility of picking up a 6 bolt from a GVR4 to drop in.
Are there any issues with this swap?
Is it pretty much a one to one fit or are there concerns with vac lines, motor mounts and different sensors/connectors?
Thanks in advance!
Yeah, just drop the engine in but use your sensors (i.e. TPS, CAS, etc.).
You'll need a 6 bolt water neck. The radiator cap in the vr4 is on the radiator and not the water neck like our DSM's.
Okay so use my sensors, check
The 7-bolt water neck is different than the 6 bolt?
Thanks guys for the impute!
