1g knuckle wont align
shawnr1215
May 6, 2013
albrightsville, Pennsylvania
i replaced my wheel bearing and cant get all the knuckle holes aligned. I can either get the two strut bolts or the lower ball joint?!?!? wtf? HELP
well it slides all the way in the hub and im almost positive its seated in the trans good too. Ive had this problem before and solved it but it was a while back so I don't remember the solution LOL. how do I seat the axle better into the trans if that's the case?
Try rotating the axle cup at the trans a little, and apply firm but not jarring pressure on the axle with the knuckle/hub assy.
Don't forget to put your keys in the ignition so the steering wheel doesn't lock into position. Had that happen a couple of times and i struggled to get everything aligned.
