1g heads turbo/NT
RossY
627
Sep 27, 2002
Canton, Ohio
Is there a difference in the 1g heads for the turbo and n/t 2.0l engines. Mine just went on my turbo and i have a chance to get an n/t for cheap.
Yes. Im pretty sure that if the n/t car is a 2.0L and says "2.0L 16 valve 2000 (or some number)" then it will work. Basically if its got the same stuff on it (letters and such). Since its a 2.0L dohc, and a turbo is a 2.0L dohc it should work. Take off the stock (turbo) head and check out the underside to be sure, then check out the n/t one you want to buy first. :thumb:
