Resolved 1G Fuel pump isn't priming
It is called the MPI relay and is near the ECU in the center console. It's a big one. Before you remove anything there is a fuel pump test connector near the firewall. Apply 12v to it and see if you can hear the pump. The car doesn't prime the pump until you put the key in start.
