420A No Start! Fuel pump isn't priming.
xI Dsmman Ix
71
Mar 15, 2010
Sandwich, Illinois
Okay, I have more problem with this car, yey. Well, long story short my car started a few days ago no problem, now that it warmed up like 15 degrees my car won't start. I have MSnS, I can't hear my Wally prime the system. I just turn the car on and nothing. Like I said it worked perfect before now I don't think it's getting any fuel. Could anyone help?
Thanks in advance,
-Miguel
Get a volt meter and see if you are getting power to the pump.If you are then the wiring inside the tank is bad. There is a way to jump your pump directly in your motor compartment should be near the battery on the fire wall if you have a repair manual for your car which you should then check in there it wwill tell you exactly. Have you checked the M.P.I fuse? Or your fuel relay yet?
You don't hear it prime when you turn the key to on or when you are cranking? The fuel pump will not send fuel until the engine starts to crank over. Like daddybonez said, check the MPI fuse and relay. The fuse is on the positive terminal connector to the battery and the relay is under the dash next to the ECU.
