Resolved 1g EPROM ECU Compatability
want_a_gsx
257
3
Apr 3, 2006
Milwaukee, Wisconsin
Anyone know if an EPROM from a 92 Auto FWD DSM will work on my 91 5-speed GSX?
Searched but found mostly questions regarding whether or not 91-94 ECU's will work on a 90 DSM.
All I can think of that might be different is the difference in injector size when comparing an auto and a 5 speed.
edit: I will not be running this ECU until I get a custom Keydiver chip.
Thanks
Solution
From Jeff himself...
"The 1991-1994 Turbo ECU's are all identical. As long as its an EPROM, so you can change the code, they are interchangeable."
Thanks Nightspeed87 and Jayrolla
What had me worried was the fact that the ECU was from an automatic DSM. I don't know much about hardware/software, but I would assume that there is a special program or "chip" made to run the automatic tranny...
Solution
