Resolved 1G ECU Pins for NT to Turbo swap?
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
For the N/T to turbo conversion, when I add wires to the ecu, do I need to buy ECU pins or are the pins already in the connector just not connected to a wire? If I need to buy them, where can you purchase them?
The easy way to get ecu pins is to go to a junk yard and cut a ecu harness off a car. Most Mitsu cars should have the same pins. That way you will have about an extra 80 pins that are already crimped to a wire.
Its hard to find the exact pins from a electronic supplier, and they usually have very high minimum orders. And you would need the crimp tool.
Where i live u never see turbos in the junkyard. Mostly because me or friends buy every junk one.Sadly i treat the junkyard like a second home.Lol
