1G 1G N/T to Turbo cam swap install?
lenz
90
Jan 12, 2003
ok i have a n/t 1g, i just bought some turbo cams, both engines were 4g63's. Ok i'm gonna install them myself and i know some about the install but not everything. i don't want to redo the timing belt either. i just want to open up the valve cover and swap the cams as i have a friend hold up the cam gears and have them not move. is this gonna work???????
Should, but might I suggest that you wire the belt to the pullys and then wire them up tight to keep them out of the way and keep the belt tight to the crank as well. This way your friend won't loose circulation in thier arms when the cam swap takes 2-3 hours longer than you expect.:thumb:
