Soccerguy136
- 305
- 8
- Mar 26, 2013
Ballwin,
Missouri
Wasn't sure where to post this so I put it in Newbie Section. Anyway, my car has just started to randomly not crank. All lights are on, but when you turn the key, nothing happens. It can happen in the morning or after I just drove it somewhere. If I wait a day or so and come back, it will fire right up as though nothing happened.
The only code that is showing is a code 0022 for a Crank Angle Sensor. I don't see how that could be causing this problem though, as when it occurs, the car doesn't even try to start or turn over.
Also, it never dies. If it decides to start up, it runs perfect with no issues. I can turn it off. Go into the gym and come back 30 minutes later, turn the key to start it, and wham, nothing. It also, can't be jumped and the ECU is also rebuilt with DSMLink.
Any direction or help is appreciated as I am stumped and don't think replacing the CAS is going to help.
UPDATE: It is for sure something to do with the Crank Angle Sensor. I waited until the issue came back, cleared the code, tried to start the car, and it came right back. Will update again once I install a different sensor. I also checked the wiring, and it looked fine.
