1g dsm oil pump
92talonawd21
Nov 25, 2011
Hinesville,, Georgia
any body know anything about a high performance oil pump for 1g dsm awd 6-bolt or maybe where to get one? ive searched for a little bit and only came up with factory replacements? or when do i step up to one? thanks
Unless you are going to go with a Magnus dry sump, use an OEM pump and debur and oil the gears prior to install. Also check for any casting flashes in the front case that would impede or disturb flow.
The OEM mitsu pump works just fine. There was one on Brent rau's car when it went 6's. The 90 straight cut gears are the better option as there less likely to creep against the housing at high rpms.
