1G 1G DSM Front Lower control Arm bush removal (safe and easy option) Energy suspension poly bush
Thought I would make a video on this since I see and still see many struggle to remove this smaller frontal bush!
This takes but a few minutes and is the clean way to remove this bush with a clean surface.
IT DOES require a heating torch of some kind so bear that in mind but most of us do or will have access to some kind of heating torch.
hopefully, this helps many and you won't damage the stock sleeve which is required by ES to be retailed.
