1G CAS in 2Ga no spark
Detective Coating
936
67
Jun 26, 2008
Richmond, Virginia
Trying to get help for a buddy of mine, he has a 96 using the stock harness and stock ECU. We have wired the CAS via Magnus's writeup and RRE's V2 with no luck. We have tried 2 CAS's, one is known working from a running car. We have also tried different PT's and coil packs, also known working. The injector wires have been swapped at the ECU.
I've tried spinning both CAS's and cannot hear the fuel pump kick on at all with either one. We haven't verified that it is getting fuel but I'd rather solve a non spark problem first. The ECU visually looks fine, the boost gauge goes up and then down after 5 seconds and the CEL comes on so it is getting power. We've checked over all of the wiring numerous times with no luck, same with the fuses.
This is a non-dsmlink equipped car. The CAS is not 180 degrees out either, I've verified it numerous times. It does crank but will not fire. I'm lost at what else to check so any help is greatly appreciated.
Still watch out, because if your connection was like mine, mine kept popping the fuse when id turn a corner. I learned the hard way, my wiring caught fire because the fuse didnt blow the last time, and my ecu ground fried :(
Im glad you figured it out!
