Resolved 1G Brake booster leak
Corey medlen
Dec 22, 2016
North royalton, Ohio
So I did a quick boost leak test on my car the other day (1ga Talon TSi awd) . I noticed that I was getting a leak from my brake booster inside and outside of the cab. So I took a look at it and have been running it for awhile like this no real issues until I took my floor mats out and noticed there was a puddle of brake fluid on the floor in the cab.
My question is, do the 1ga Talons come factory with a check valve in the booster line cause I don't see one and could that be the issue to why my seals are blown out on the back of my master considering I'm also running 22psi and I feel as if a booster should only have vacuum and not be pressurized. I want to know before I do the 3g master/booster swap
