1g BOV flange question
GeneralChaos
366
Feb 13, 2004
Belleville, Michigan
ok I got my flange from slowboy, and its just a plate that bolts onto the bottom of the bov, but my question before I install is isnt there supposed to be a tube or something coming down to fit into the stock plastic pipe? or does it slide over the pipe? not sure on what to do, ive tried searching around but cant find any real answers on it, and I dont want to go tearin stuff apart if I dont have the things I need.
The flange is made to be welded onto a cutom DP. You needed the adapter kit, not the flange. You could probably get a small piece of 1.5 inch steel or aluminum tubing and have it welded on to make you're own adapter kit.
crap that sucks, do you have the exact dimensions of the tube i'll need? 1.5" diameter and how long? ill try to get the pipe and have my buddys dad weld it for me friday.
Look at the hole in the middle of bov adapter plate. You need a 1 1/2 or 1 inch circular tube coming down off of that. That's it. Just bring that flange with you and mat up a piece of piping....
No don't use the flange as a referance. Take off you're old bov, take that little rubber gaskit/spacer around the base of the bov and use that. That way you're sure to get a pipe that will fit in your upper intercooler pipe since that's the important part.
Devicex said:
Please dont weld the BOV flange to your downpipe.
:D
LOL im not stupid, I just ask a few small dumb questions here and there...and there..and...well you get the point :rolleyes:
  • Wanted 6 bolt NT water pipe
    • chrisman287
